Cleaning engine block? Steam clean...
bmw9818
Post Sun Jul 22, 2012 2:06 pm
Got loads of grime and oil on the block possible to use a wallpaper stripper as a steam cleaner and will it come off?
Wiring is gonna be renewed to 1.3 so not an issue heads off as well shoul I obv avoid targeting the alternator and starter and just the bottom half?
Topblag
Post Sun Jul 22, 2012 2:12 pm
I spray the engine with TFR then hose it off. If it's heavier grime, use spray on gunk. Work it in to the worst areas with a brush of some sort and be careful with water near the electrics.
You'll be pleasantly surprised how much dirt it'll remove.
I used to leave the engine running and clean it with a hot power washer, which essentially put out hot steam. Never brought any problems.
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
bmw9818
Post Sun Jul 22, 2012 2:38 pm
cool spent enuff money on this car allready! tfrs a bit much, will just use the wallpaper stripper with a nozzle to clean it up as best it does,
Topblag
Post Sun Jul 22, 2012 3:12 pm
I'd suggest you use a degreaser, it'll work well with the steam.
Gavla
Post Sun Jul 22, 2012 7:49 pm
I used Astonish Engine Degreaser on my engine, worked an absolute treat!
At £1.25 a bottle from Amazon you can't go go wrong. Use a couple of bottles if necessary it really made my engine look brand new.
mcbonio
Post Sun Jul 22, 2012 8:50 pm
Yeah I used a litre a engine degreaser in a squirty bottle, spray it on, leave it to soak for 15 mins then the same squirty bottle with fresh water to rinse. Spotless.! Again take care with with the electrical components.
Don't be too alarmed at the steam from the engine when you run it mind.!
Post Sun Jul 22, 2012 10:11 pm
Just remember anything you degrease will have zero protection from the elements once your done, the oil thats been stuck to everything for the last 20 odd years will have been doing a great job of keeping everything rust free. I prefer to use 3-in-1 spray oil or similar with a stiff brush to leave a bit of a protective layer behind
Topblag
Post Sun Jul 22, 2012 10:24 pm
that's good advice.
bmw9818
Post Sun Jul 22, 2012 10:41 pm
nice one, with the rust issue allready got some waxoyl etc to go around the engine bay, so that should be cool, engine block is fairly solid,
