635 CSI M52 Conversion Possible?
BMWE30325
Post Sat Jul 21, 2012 9:58 am
as above would it be very hard to do or similar to the e30 conversion?
ajay
Post Sat Jul 21, 2012 10:08 am
Im sure its possible with out too much dificulty but an m52 would not output as much tourqe as the m30 that the 6 series comes with.
e21Jason
Post Sat Jul 21, 2012 10:14 am
Been done on a e28 so possible yes
jason
BMW e21 track car supercharged s14 cage and fabrication by www.chizfab.com
Z3M Coupe for sale
69 Alfa spyder
Post Sat Jul 21, 2012 10:53 am
Only if you want to spend lots of money to go slower and have a car that is worthless after all the dramas :?
anothere21323i
Post Sat Jul 21, 2012 10:55 am
pacerpete wrote:Only if you want to spend lots of money to go slower and have a car that is worthless after all the dramas :?
In a nutshell!
Why bother when you could have this beast instead?
http://www.ebay.co.uk/itm/1982-BMW-E24- ... 2a2032de59
BMWE30325
Post Sat Jul 21, 2012 2:32 pm
so is the 3.5 better engine than the m52?
Post Sat Jul 21, 2012 2:50 pm
No, not at all, BUT it is a much better engine for a 635 :)
Post Sat Jul 21, 2012 7:08 pm
M52 in a E24. How wrong would that look? :eek:
[youtube][/youtube]
Post Sat Jul 21, 2012 7:58 pm
Blitz wrote:M52 in a E24. How wrong would that look? :eek:
[youtube][/youtube]
Congratulations Yuri, have a cabbage.
The turd that you have spent many months ruining is a sorry piece of scrap :(
cecotto479
Caution Unreliable Seller
Post Sat Jul 21, 2012 9:37 pm
The factory put the V12 in to build the 850 development mule. There's been a few of them done.
M52 is pointless. Best conversion for a b34 is b35.
1981 E23 735i
Post Sat Jul 21, 2012 9:55 pm
[youtube][/youtube]
Shouldn't that be an Asparagus? :rolling:
snakebrain
Post Sun Jul 22, 2012 8:16 pm
cecotto479 wrote:The factory put the V12 in to build the 850 development mule. There's been a few of them done.
5.0 V12 in an E24 just oozes rightness!
sweep
Post Sun Jul 22, 2012 8:35 pm
Rover sd1 v8 powerhouse!?
Andyboy
Alpina Colada
Post Sun Jul 22, 2012 10:56 pm
2.8 Ford Cologne V6 for the win.
Post Mon Jul 23, 2012 11:52 am
Nah, what you want is the 2-litre Ford Pinto lump, as some Irish bogshoite fitted in an E36.
Preferably with a very worn camshaft, so that it clatters in an agricultural way.
cecotto479
Post Mon Jul 23, 2012 12:26 pm
Fiat twin cam?
1981 E23 735i
Post Mon Jul 23, 2012 1:44 pm
Actually, that probably wouldn't be so bad in a 635CSi, as they are extremely torquey in 2-litre form.
Phill172
Post Mon Jul 23, 2012 2:29 pm
Always wanted one with a e60 35 diesel...... :o:
But big car either v8 or v12
sweep
Post Mon Jul 23, 2012 10:08 pm
Crossflow......
Dan320is
Post Mon Jul 23, 2012 10:34 pm
A series or CVH.
anothere21323i
Post Mon Jul 23, 2012 10:48 pm
Another boat anchor - BMC C Series......
duracel79
Post Tue Jul 24, 2012 8:19 am
Sounds like a great idea to put an M50 into an E24 :roll: ........................
With a Turbo winkeye
Andyboy
Alpina Colada
Post Tue Jul 24, 2012 12:14 pm
A Rover 2300 straight six with a single turbo blowing through three Ford VV carbs on a cast iron log manifold.
Post Tue Jul 24, 2012 4:40 pm
Now you're talking, though I would personally prefer to use the Austin Princess 2.2 straight-six. :wink:
Andyboy
Alpina Colada
Post Tue Jul 24, 2012 10:36 pm
Aah, the redoubtable E6. She'd benefit from some headwork but surprisingly, not a bad engine. The Rover unit was okay (the 2600 was very pokey) but the oil drain back valve scuppered many - it used to block, starving the head Nd cam of oil. Standard Leyland dealer practice was to unscrew the valve and give it a distance test* before fitting a replacement head with the valve omitted. Worked fine and increased the oil supply to the cam.
*see how far it can be thrown.
Post Tue Jul 24, 2012 11:09 pm
Let's not forget the AMC Pacer engine; a vast 3.8/4.2-litre boat anchor that could only muster about 100 bhp and return 17 mpg average. Party on - NOT!
And then, there's the Ford Zephyr/Zodiac lump - I saw a VW Beetle with one hanging out the back of it once; the handling must have been lethal!
Still, both worthy candidates for dropping into an E24...
Eddie25
Post Thu Aug 23, 2012 1:48 pm
Big Block Mopar winkeye
Rust is lighter than carbon fibre.
snakebrain
Post Thu Aug 23, 2012 1:52 pm
Here's a very, very nice S54 installation into an E28 that might give you food for thought..
http://www.mye28.com/viewtopic.php?t=108450
