635 CSI M52 Conversion Possible?
BMWE30325
as above would it be very hard to do or similar to the e30 conversion?
ajay
Im sure its possible with out too much dificulty but an m52 would not output as much tourqe as the m30 that the 6 series comes with.
e21Jason
Been done on a e28 so possible yes
jason
jason
BMW e21 track car supercharged s14 cage and fabrication by www.chizfab.com
Z3M Coupe for sale
69 Alfa spyder
Z3M Coupe for sale
69 Alfa spyder
Only if you want to spend lots of money to go slower and have a car that is worthless after all the dramas
anothere21323i
In a nutshell!pacerpete wrote:Only if you want to spend lots of money to go slower and have a car that is worthless after all the dramas
Why bother when you could have this beast instead?
http://www.ebay.co.uk/itm/1982-BMW-E24- ... 2a2032de59
BMWE30325
so is the 3.5 better engine than the m52?pacerpete wrote:Only if you want to spend lots of money to go slower and have a car that is worthless after all the dramas
BMWE30325 wrote:so is the 3.5 better engine than the m52?pacerpete wrote:Only if you want to spend lots of money to go slower and have a car that is worthless after all the dramas
No, not at all, BUT it is a much better engine for a 635
M52 in a E24. How wrong would that look?
[youtube][/youtube]
[youtube][/youtube]
Blitz wrote:M52 in a E24. How wrong would that look?
[youtube][/youtube]
Congratulations Yuri, have a cabbage.
The turd that you have spent many months ruining is a sorry piece of scrap
cecotto479
- Caution Unreliable Seller
The factory put the V12 in to build the 850 development mule. There's been a few of them done.
M52 is pointless. Best conversion for a b34 is b35.
1981 E23 735i
Shouldn't that be an Asparagus?pacerpete wrote:Blitz wrote:M52 in a E24. How wrong would that look?
[youtube][/youtube]
snakebrain
5.0 V12 in an E24 just oozes rightness!cecotto479 wrote:The factory put the V12 in to build the 850 development mule. There's been a few of them done.
sweep
Rover sd1 v8 powerhouse!?
Andyboy
- Alpina Colada
2.8 Ford Cologne V6 for the win.
Nah, what you want is the 2-litre Ford Pinto lump, as some Irish bogshoite fitted in an E36.
Preferably with a very worn camshaft, so that it clatters in an agricultural way.
cecotto479
Fiat twin cam?
1981 E23 735i
Actually, that probably wouldn't be so bad in a 635CSi, as they are extremely torquey in 2-litre form.
Phill172
Always wanted one with a e60 35 diesel......
But big car either v8 or v12
sweep
Crossflow......
Dan320is
A series or CVH.
anothere21323i
Another boat anchor - BMC C Series......
duracel79
Sounds like a great idea to put an M50 into an E24
With a Turbo
With a Turbo
Andyboy
- Alpina Colada
A Rover 2300 straight six with a single turbo blowing through three Ford VV carbs on a cast iron log manifold.
Now you're talking, though I would personally prefer to use the Austin Princess 2.2 straight-six.
Andyboy
- Alpina Colada
Aah, the redoubtable E6. She'd benefit from some headwork but surprisingly, not a bad engine. The Rover unit was okay (the 2600 was very pokey) but the oil drain back valve scuppered many - it used to block, starving the head Nd cam of oil. Standard Leyland dealer practice was to unscrew the valve and give it a distance test* before fitting a replacement head with the valve omitted. Worked fine and increased the oil supply to the cam.
*see how far it can be thrown.
Let's not forget the AMC Pacer engine; a vast 3.8/4.2-litre boat anchor that could only muster about 100 bhp and return 17 mpg average. Party on - NOT!
And then, there's the Ford Zephyr/Zodiac lump - I saw a VW Beetle with one hanging out the back of it once; the handling must have been lethal!
Still, both worthy candidates for dropping into an E24...
Eddie25
Big Block Mopar
Rust is lighter than carbon fibre.
snakebrain
Here's a very, very nice S54 installation into an E28 that might give you food for thought..
http://www.mye28.com/viewtopic.php?t=108450
