Whats the best body filler?
e30bb
Used Davids from good old trusty halfords.
The stuff seems ok.
Is there better stuff out there?
The stuff seems ok.
m-dtech
- Unapproved Trader caution
naw they are all as porus as each other.
dont use filler unless u really have to
Simon
Pacemaker Pete is your man!
jonb
i last heard pete had shares in p38.
i use trade stuff, cant remember the name. its so much cheaper than all the well known brands.
U POLL GALV X mate.
I was using it everyday a couple of years ago in my 'then' line of work. "(pannel beater)" And it is the best and easiest ive used so far
If P40 is good enough for corvettes , reliant robins and Scott325SE its good enough for me !
P.S when doing 'major repairs' best to build it up with cardboard and newspaper (preferably an upmarket title like the times ) then layer on the P40 then finish with a skim of p38 or similar, thats how JonB taught me and he's an expert !
TOURINGDADDY
andyp
- True Old Skooler
pacerpete wrote:If P40 is good enough for corvettes , reliant robins and Scott325SE its good enough for me !![]()
well you sound like the expert to me, i use the sun when doing mine as for filler use u-pol it is alot easier to rub down
AndyP , i obviously 'repair' a better class of car than you hence the times, the sun is sooo chrome and council !
calipsodream
top stop gold is good ive used it a lot. but i allso use a lot of lead on some jobs lasts longer
e30bb
Lead, cool!calipsodream wrote:top stop gold is good ive used it a lot. but i allso use a lot of lead on some jobs lasts longer
Seen it done on home discovery or men and motors, a program called hot rod something.
It looks easy, heat the stuff up, slap it on the dent and grind it smooth (or is it)?
Did some research on the net and found out its harmful to ur body and stuff.
Can I buy the stuff in the uk?
Do u need and special primer for it?
johnna
- E30Zone Irregular
The best filler is new steel IMHO....
Go back to metal, remove all rust and sweat in new steel with a mig, then grind/ file/ sand it back.
EASY!!!
Even the best repairs benefit from a skim of filler. The secret is to keep it dry then to get paint on it as soon as you can. Not only is filler porous, it is quite absorbent too.
EASY!!!
scottybeemer
i work on new bodys before they are cars and we use a lot of panel beating/sanding etc. and sometimes solder
"you aint gonna take me alive, copper"
e30bb
I used P38 for a hole in the roof of my old 316 it started cracking up after a year.
I think I ll have a go at lead for a small dent on the boot.
Lead melts to liquid, should be easy.
Well test out on some old panels.
Dont get too caried away with the heat though,
a large flat panel will warp and you will end up emptying that can of filler!
