I posted up a while ago that I needed to change my sump gasket.
I think andyboy recommended a particular brand of gasket.
Has anyone got experience of the best gasket to use?
Scott
M20 B25 Sump Gasket ????
scott180gtb
Cars
2007 VW Caravelle 2.5 TDI 250 bhp 550 NM
1989 325i Sport Gone
2003 E46 320d Touring
1998 E36 M3 EVO Track Toy
1996 E36 328i Sport welder-up project
maggspower
- Turbo Farmer Tractor Driver
A word of warning, the BMW ones are the cork ones. I ordered two thinking BMW would sell the superior paper type ones, but not. I'm sure they will last a good while, long enough for me to forget what a cr4p job it is to do with the engine in situ at least
I was thinking of using a sealant, as, used correctly, I think this would last very well. The key words here are "used correctly".
Sorry for not being more help.
Grrrmachine
- E30 Zone Wiki / Team Member
Yeah, i just fitted a BMW one and it was a feeble little cork thing too. Having read through the archives, I'll now be going back and fitting a bead of sealant around it too.
HairyScreech
Liquid stalent used properly is fine. Few oil pan flanges are still flat 20 years down the line.
(damn auto correct)
(damn auto correct)
aimlessrock
when i re-did mine i used both gasket and locktite sealer as the gasket looked a little feeble (oem)..Maggs on a 6 pot its a horrid job to do..i resorted to lifting the engine of its mounts to clear the crossmember...shite job.
E30 320i Convertible (1989)
190 Mercedes (1988)
190 Mercedes (1988)
Andyboy
- Alpina Colada
Use the card one. I think Payen do them but it's easy toake one from thick gasket paper. Also use theadlock on the sump bolts so they don't work loose.
scott180gtb
I managed to get the sump off this afternoon. Half the bolts on the drivers side were hand tight
There is loads of info on the net saying that you have to lift the engine to get the sump off. All I have done is remove the steering rack and hey presto.
Paper gasket and lock thread as Andy recommended. If it leaks I can always ream him at the pod!
Cars
Andyboy
- Alpina Colada
Words. Just words you bitch.
spook
- League two here we come !!!
Ive done the sump gasket with the engine in the car, its not much fun trying to feed the oil pump feed pipe back in, but its do able.
