Extra battery in the boot
smithy318i
Post Thu Nov 17, 2005 1:08 pm
Whats involved in adding a second battery in the boot ?
dazleeds
old skool raver
old skool raver
Post Thu Nov 17, 2005 1:12 pm
as far as i know
all ya need is the fat cable
which beemerlad has
and poss some sort of splitcharge circuit
usually readily available at landrover dealers etc as they use em a lot
hth
Daz
ps maybe a bigger alternator
which lee also has i think :cool:
www.oldskoolfantasy.co.uk
Post Thu Nov 17, 2005 1:14 pm
cheers Dazzle
Smithy, PM me if you are interested in the cable, it is in my thread with the morsels, complete with battery terminal clips and the connectors that go onto the bulkhead :wink:
bootyman
Post Thu Nov 17, 2005 1:15 pm
I'm interested in this too as i will have to get one fitted so i can run my screens at shows. At the moment, i can only have them on for a couple of minutes, then i have to switch my engine on to charge the battery or it goes flat :( I bought one of those Yellotop ones, but it was too tall and my bonnet wouldn't shut :cry:
dazleeds
old skool raver
old skool raver
Post Thu Nov 17, 2005 1:18 pm
no prob lee :thumb:
Booty mate
im surprised you havent done it yet with all the kit your running
quite easy to do and fookin usefull if you can switch to either battery in case of flat etc
splitcharge circuit are pretty cheap afair
gonna be doing this to mine as a precaution and to run set up etc
had too push too many cars due to fooked batts in past :roll:
Post Thu Nov 17, 2005 1:20 pm
first with the cheque or paypal gets it, Ben, would u need this posting to Italy or Laaaandon geeza?
can't even remember how much I was asking for it now :roll: :mad:
smithy318i
Post Thu Nov 17, 2005 1:22 pm
ben can have it.
Im just thinking about it as my battery went flat after 10 minutes of playing music without the engine running.
bootyman
Post Thu Nov 17, 2005 1:34 pm
I have to speak to my ICE man 1st dude. I dont know how he'll want to do it, but i'll come back to you if he gives me the go ahead mate :wink:
Daz, i should have had it done, but cause i though the yellow top was going in the car, i never bothered, but when it didn't fit i couldn't do anything cause my boot install was already done. Now i'll have to get my trimmer top rip it all out and do it cause it's a show stopper when you can have all your screens running at shows. Even better when you can show something different on each screen. winkeye
placey
Post Thu Nov 17, 2005 3:20 pm
ben
i don't know what battery you're running at the minute but some careful measurements and a trip to a factors to purchase a diesel battery will give you a reasonable bit of car park time. it's what i've done with mine and you what i'm running.... mine's not gone flat yet...
paul
i saw a doctor and she gave me some pills....
bootyman
Post Thu Nov 17, 2005 3:26 pm
Hi Paul. I've just texed my ICE man and he said he'll install a spare one in the boot when i bring the car back to have my neons in the boot and the mirrors changeed. I actually took 3 yellowtops to the garage garage, but the fcuker has closed up and fcuked off to India for good, so i'm stuffed and will have to buy a new one :(
Where you been hiding any Paul ? :D
placey
Post Thu Nov 17, 2005 3:57 pm
where have i been hiding? i've been keeping a low profile as i extended myself financially buying another house and setting it up then buying us a business van (ford escort shed mechanically sound but comprehensively corroded) and putting it back on the road - a mini project. soon as i'm back on my feet so to speak i'll be hunting down an m-tech 1 project.
anyways - my understanding of batteries is that a second battery doesn't require a split charger so long as it's run in parallel, the car effectively sees a large battery. the two batteries have to be the same spec and age for this to work however. what is good is an isolating key - so that the 'remote' battery can be disconnected and used for starting the car after any car park time is done. a split charger is nice of course and necessary for more than 2 battery setups.
as far as installing goes the second battery can be placed in the boot/under the bonnet whereever the first one isn't and cabled in with 4 gauge or larger. e30s are particularly easy as they have 2 factory locations!
paul
