Sump guard
mcbonio
Post Sun Jul 01, 2012 11:18 pm
Wanting to fix a sump guard on my 325 as the sump is only 4 fingers off the floor. Not ideal.
There is a seller on here selling aluminium ones for 80 quid, he says you might want to cut air holes in it to get cool air onto the sump.
My question is, if the 325i has an oil cooler, is there much point of drilling holes in the sump guard to get a bit of air onto it?
Screacher
Post Mon Jul 02, 2012 8:28 am
I run one of RPM's steel guards on my track 325i. It has 16 x 1" holes in it (approx size). Temps are never above 85deg C on track and a lot lower on the road. Not sure what they'd be if it didn't have the holes in it.
mcbonio
Post Mon Jul 02, 2012 9:06 am
Cheers fella, do you have to remove it for an oil change? Or can you access the sump nut with it on?
Also, the RPM skid plate, did you have to drill any extra on the car holes to mount it?
Screacher
Post Mon Jul 02, 2012 6:47 pm
Mine's a prefacelift so had to drill an additional hole in the front. Wasn't a big deal to be honest. Unfortunately, I do have to remove the guard to change oil as it is pretty close to the sump plug. I guess I could try one of those plugs which have a tap included and see if it's possible to attach a pipe to drain it. However, TBH, it's not a major problem to remove the guard as it also gives a chance to check other bits'n'bobs down there.
mcbonio
Post Mon Jul 02, 2012 8:35 pm
Cheers screacher,
Yeah mines a prefacelift cab, looks like I'll be adding a few holes to her.!
Screacher
Post Mon Jul 02, 2012 9:26 pm
Somehow, I also had a hole that I didn't need. Despite having the guard on almost since it was built, I found a tiny crack in the front of the sump :eek: I've had it ally-welded and all seems OK now, but an added advanatge of a sump guard is that you can check how much is being lost. Thankfully, all is dry now :)
