power steering belt?
gman1
Post Tue Jun 26, 2012 9:51 pm
Hi all,
My 318is baur is making a "screeching" sound when turning the steering wheel when parked.....i was told the power steering belt needs tightening?..
Can anyone tell me which belt it is and a rough guide on how to do it????..
Many thanks...
Post Tue Jun 26, 2012 11:16 pm
the p/s beltis the front one nearest the rad,it has a 13mm nut locking a 19mm [spanner size] adjusting nut that when turned will tighten or slacken the belt .
no's 12 and 13 ,don't forget to tighten 13 when done :wink:
Post Tue Jun 26, 2012 11:17 pm
if the pump is on it's way out i have a few for sale.
gman1
Post Wed Jun 27, 2012 7:25 am
Ok thankyou.....i'll have a look when i get chance...
DHFiS
Post Wed Jun 27, 2012 7:51 am
Ease off the bolt the pump pivots on whilst moving it with part 12 in the diagram above
Post Wed Jun 27, 2012 9:26 am
8,10 and 13 should all be slackened off very slightly, and the adjustment made by turning 12.
Only slacken 13 just enough to let 12 wind along the rack (9), or the teeth on 13 will slide off of the matching teeth on 9, damaging both parts.
Tighten all that you slackened to complete the job.
