Standard Disks/ Upgrade Pads????
scott180gtb
Post Fri Jun 15, 2012 7:36 pm
Welcome Back
I've been waiting all week to ask this question. I know its been posted many times but a quick search is not helping me.
I'm rebuilding the arse end of my 325 at the minute and I'm just about to mount the callipers.
I have standard disks and I'm thinking, would a pad upgrade be worth while?
No track action for this turd but I do enjoy a good road thrashing.
What does the zone recommend.
Scott
Cars
2007 VW Caravelle 2.5 TDI 250 bhp 550 NM
1989 325i Sport Gone :(
2003 E46 320d Touring
1998 E36 M3 EVO Track Toy
1996 E36 328i Sport welder-up project
Post Fri Jun 15, 2012 7:45 pm
Black diamond grooved discs and either green,red or yellowstuff pads will keep you out of the hedges.
i have red stuff pads but standard discs .i've heard to avoid drilled/grooved discs as they warp easier than just grooved ones . whether thats true or not i don't know .
redcar
Post Fri Jun 15, 2012 8:11 pm
I've just got the ebc dimpled and grooved discs on the front, standard pagid on the rear. Ebc green stuff all round for pads, and pagid brake fluid. All new parts.
Never overheated the brakes on the road, only a 318is...
However, in the 316i, brakes would overheat and pedal would go straight to the floor.
This would suggest an average/renewed brake setup is much better than an older and possibly inferior quality parts. I would imagine brand new oem quality gear would be great. Remember a good brake fluid.
Grrrmachine
E30 Zone Wiki / Team Member
Post Fri Jun 15, 2012 9:02 pm
Rear end carries very little of the braking, proportionally, so if you're not going to be thrashing the car on a track then you'll see little return on using more expensive pads.
Good quality OEM pads should be enough.
redcar
Post Fri Jun 15, 2012 10:31 pm
Grrrmachine wrote:Rear end carries very little of the braking, proportionally, so if you're not going to be thrashing the car on a track then you'll see little return on using more expensive pads.
I think you may be surprised regarding pads and discs on the back and how much the rears do in fact contribute to the overall braking of the car.
Post Fri Jun 15, 2012 10:32 pm
rear brakes are on a stick for skids innit :D
redcar
Post Fri Jun 15, 2012 10:41 pm
magpie wrote:rear brakes are on a stick for skids innit :D
Hydro wand skidz required winkeye
Grrrmachine
Post Sat Jun 16, 2012 8:15 am
I stand corrected :) In compensation, have a Wiki link:
http://www.e30zone.net/e30zonewiki/inde ... s#Upgrades
redcar
Post Sat Jun 16, 2012 9:09 am
I think the comparison between a ds2500 and an ebc yellow is somewhat optimistic winkeye
**BANNED**
Post Sat Jun 16, 2012 10:08 am
I would add s/s braided flexi's to your shopping list,stiffens the pedal feel up no end.
I have to have a look at the touring's rear brakes sometime soon,I will be using standard GSF supplied disc's,but I will be buying EBC greenstuff pads.This will be a first for rear brakes,although the fronts on the touring have greenstuff pads.
Youth is wasted on the young.
Kos
Post Sat Jun 16, 2012 10:27 am
I wouldn't use green stuff on an e30
Reds would be a minimum and can take a battering
redcar
Post Sat Jun 16, 2012 11:14 am
Kos wrote:I wouldn't use green stuff on an e30
+1
toby
Post Sat Jun 16, 2012 11:58 am
I like the standard BMW pads from the dealership for wear and no squealing. Those EBC pads are awful on a road car.
BEERBOY123
Post Sat Jun 16, 2012 1:47 pm
My standard dealer pads do squeak, although they are going to sort them.
I was surprised though, possibly faulty batch.
Two headblenders, couple of bags of MC Hammer, 5 litres of FFF, a 48ft bastard, a box of jumped-up custard and some soggy chimps
Barx325i
Post Sat Jun 16, 2012 1:53 pm
I set fire to some green stuff on black diamond discs up front ....in a pug 1.9DT
I'd say red stuff but I've heard they take a bit to get them up to temp, so probably not ideal for a daily? Never used them though
penton08
Post Sat Jun 16, 2012 4:10 pm
EBC greens are shocking imo, your better off with cheap pagid/textar stuff. Reds work fine from cold and are OK on a standard e30.
