Standard Disks/ Upgrade Pads????
scott180gtb
Welcome Back
I've been waiting all week to ask this question. I know its been posted many times but a quick search is not helping me.
I'm rebuilding the arse end of my 325 at the minute and I'm just about to mount the callipers.
I have standard disks and I'm thinking, would a pad upgrade be worth while?
No track action for this turd but I do enjoy a good road thrashing.
What does the zone recommend.
Scott
Scott
Cars
2007 VW Caravelle 2.5 TDI 250 bhp 550 NM
1989 325i Sport Gone
2003 E46 320d Touring
1998 E36 M3 EVO Track Toy
1996 E36 328i Sport welder-up project
Black diamond grooved discs and either green,red or yellowstuff pads will keep you out of the hedges.
i have red stuff pads but standard discs .i've heard to avoid drilled/grooved discs as they warp easier than just grooved ones . whether thats true or not i don't know .
+ a yard full of scrap turds
redcar
I've just got the ebc dimpled and grooved discs on the front, standard pagid on the rear. Ebc green stuff all round for pads, and pagid brake fluid. All new parts.
Never overheated the brakes on the road, only a 318is...
However, in the 316i, brakes would overheat and pedal would go straight to the floor.
This would suggest an average/renewed brake setup is much better than an older and possibly inferior quality parts. I would imagine brand new oem quality gear would be great. Remember a good brake fluid.
Grrrmachine
- E30 Zone Wiki / Team Member
Rear end carries very little of the braking, proportionally, so if you're not going to be thrashing the car on a track then you'll see little return on using more expensive pads.
Good quality OEM pads should be enough.
redcar
I think you may be surprised regarding pads and discs on the back and how much the rears do in fact contribute to the overall braking of the car.Grrrmachine wrote:Rear end carries very little of the braking, proportionally, so if you're not going to be thrashing the car on a track then you'll see little return on using more expensive pads.
rear brakes are on a stick for skids innit
redcar
Hydro wand skidz requiredmagpie wrote:rear brakes are on a stick for skids innit
Grrrmachine
I stand correctedredcar wrote:I think you may be surprised regarding pads and discs on the back and how much the rears do in fact contribute to the overall braking of the car.Grrrmachine wrote:Rear end carries very little of the braking, proportionally, so if you're not going to be thrashing the car on a track then you'll see little return on using more expensive pads.
http://www.e30zone.net/e30zonewiki/inde ... s#Upgrades
redcar
I think the comparison between a ds2500 and an ebc yellow is somewhat optimistic
- **BANNED**
I would add s/s braided flexi's to your shopping list,stiffens the pedal feel up no end.
I have to have a look at the touring's rear brakes sometime soon,I will be using standard GSF supplied disc's,but I will be buying EBC greenstuff pads.This will be a first for rear brakes,although the fronts on the touring have greenstuff pads.
Youth is wasted on the young.
Kos
I wouldn't use green stuff on an e30
Reds would be a minimum and can take a battering
redcar
+1Kos wrote:I wouldn't use green stuff on an e30
toby
I like the standard BMW pads from the dealership for wear and no squealing. Those EBC pads are awful on a road car.
BEERBOY123
My standard dealer pads do squeak, although they are going to sort them.
I was surprised though, possibly faulty batch.
Two headblenders, couple of bags of MC Hammer, 5 litres of FFF, a 48ft bastard, a box of jumped-up custard and some soggy chimps
Barx325i
I set fire to some green stuff on black diamond discs up front ....in a pug 1.9DT
I'd say red stuff but I've heard they take a bit to get them up to temp, so probably not ideal for a daily? Never used them though
penton08
EBC greens are shocking imo, your better off with cheap pagid/textar stuff. Reds work fine from cold and are OK on a standard e30.
