can i run a 1.8 diff/props with 2.0 running gear?
matt86
Post Fri Jun 08, 2012 12:40 am
Can I run a 1.8 diff and props with 2 litre running gear, both from facelift convertibles?
If so will it make the acceleration/gearing different? and if so how?
thanks
Grrrmachine
E30 Zone Wiki / Team Member
Post Fri Jun 08, 2012 8:07 am
The 1.8 and 2.0 diff is the same; a small-case unit. To confirm, count the number of bolts holding on the back plate of the diff (should be six).
The prop however is relative to the gearbox as well, so if you've transplanted in an M20B20 engine complete with its Getrag 240 box, there's a chance you'll need the prop to match because the back end of the gearbox will sit in a different position.
The one piece of info you need is the length of a 318i prop; unfortunately, it's not in the Wiki :(
zaust
Zone day release
Post Fri Jun 08, 2012 9:31 am
Mb20 engine with matching gearbox and prop. You are only swapping the diff so will be a straight swap.
M30 Tech 1 Touring on gas.
matt86
Post Fri Jun 08, 2012 12:13 pm
cheers both, so I just need the 2 litre engine, box, wiring loom, ecu, exhaust manifold and prop?
is the whole exhaust system different, or is it only the mainfold because its six cylinder?
cheers
**BANNED**
Post Fri Jun 08, 2012 12:25 pm
Exhaust should be a twinpipe system on the proper engine,lesser engine's have a single pipe from the centre box rear-wards. One slight issue could be the exhaust exit point in the rear valance,when I fitted my 2.7 M20 into my ex318i engined cabbie,I asked my bodyman to modify the rear valance as he worked his way around the body.
A DiY fix is to attack the area with an angle grinder fitted with a slitting disc.... :mad:
Youth is wasted on the young.
matt86
Post Fri Jun 08, 2012 12:28 pm
Thanks mate, will bear this in mind, so basically I need to get the whole exhaust system really second hand from somewhere.
cheers
**BANNED**
Post Fri Jun 08, 2012 1:40 pm
Perhaps this will help!
