Can I run a 1.8 diff and props with 2 litre running gear, both from facelift convertibles?
If so will it make the acceleration/gearing different? and if so how?
thanks
can i run a 1.8 diff/props with 2.0 running gear?
matt86
Grrrmachine
- E30 Zone Wiki / Team Member
The 1.8 and 2.0 diff is the same; a small-case unit. To confirm, count the number of bolts holding on the back plate of the diff (should be six).
The prop however is relative to the gearbox as well, so if you've transplanted in an M20B20 engine complete with its Getrag 240 box, there's a chance you'll need the prop to match because the back end of the gearbox will sit in a different position.
The one piece of info you need is the length of a 318i prop; unfortunately, it's not in the Wiki
zaust
- Zone day release
matt86
cheers both, so I just need the 2 litre engine, box, wiring loom, ecu, exhaust manifold and prop?
is the whole exhaust system different, or is it only the mainfold because its six cylinder?
cheers
cheers
- **BANNED**
Exhaust should be a twinpipe system on the proper engine,lesser engine's have a single pipe from the centre box rear-wards. One slight issue could be the exhaust exit point in the rear valance,when I fitted my 2.7 M20 into my ex318i engined cabbie,I asked my bodyman to modify the rear valance as he worked his way around the body.
A DiY fix is to attack the area with an angle grinder fitted with a slitting disc....
Youth is wasted on the young.
matt86
Thanks mate, will bear this in mind, so basically I need to get the whole exhaust system really second hand from somewhere.
cheers
cheers
- **BANNED**
Perhaps this will help!
