More progress with the touring
Simon
Post Tue Nov 15, 2005 7:43 pm
Work goes on!! I am preparing for an engine change for the touring, I think it's going to be a 2.7 now to keep things on a budget.
All new springs and shocks, new wishbones, new bushes, trailing arm bushes, upgraded brakes all round, and weekend just gone saw new diff bush (Z3) 3.64 LSD, new guibo and prop doughnut, and Z3 shifter with all new shift components, the shift was so bad, the lever would hit the centre console, the improvement is 101%!
Early next year will see a full respray in the standard Diamond Black, and then hopefully replacement engine.
Post Tue Nov 15, 2005 7:46 pm
eta bottom end with 320i head and 2.5 inlet yeah?
Sounds good.. im v tempted to get a Touring :eek:
Dominitry
Post Tue Nov 15, 2005 7:48 pm
Simon, you do know Richys gonna start crying when he reads this lol
Simon
Post Tue Nov 15, 2005 7:49 pm
Jhonno wrote:eta bottom end with 320i head and 2.5 inlet yeah?
I think this will be the route I'll take.
glenn
Engine Transplant Services
Post Tue Nov 15, 2005 7:50 pm
Dominitry wrote:Simon, you do know Richys gonna start crying when he reads this lol
i thought the very same thing, craig
Simon
Post Tue Nov 15, 2005 7:51 pm
:lol:
Have you got an e-mail addy for Richy?
I meant to phone him back the other day, but I've never got credit on my phone. :oops:
billgatese30
Post Tue Nov 15, 2005 7:53 pm
sweet....i bet your lass is well pleased...seeing as she drives it as much as you do :cool:
Andy335Touring
A lot of work/money there Si but the car is going to be transformed when its done ! :cool:
A Black M-Tech Touring is a very cool car, even better with a 2.7 :thumb:
Dominitry
Richys e mail addy PM'd.
Simon
Post Tue Nov 15, 2005 7:54 pm
billgatese30 wrote:sweet....i bet your lass is well pleased...seeing as she drives it as much as you do :cool:
ermmm...yeah! :twisted:
Simon
Post Tue Nov 15, 2005 7:55 pm
Dominitry wrote:Richys e mail addy PM'd.
Thanks mate, all received!
Simon
Post Tue Nov 15, 2005 7:58 pm
Andy335Touring wrote:A lot of work/money there Si but the car is going to be transformed when its done ! :cool:
Yeah, paintwork I'm more excited about though!!
Guys, anyone know how to get the bumpers sitting properly again, they don't line up with the arches, I'm sure most know what I mean, looks like the cars been very lightly bumped in the past, most E30's I see have the problem, is it just a case of getting new mounts?
RustyRuss
Post Tue Nov 15, 2005 9:11 pm
Best of luck with it all, sounds like an interesting project :)
Russell A Macfarlane
Central Scotland
Post Tue Nov 15, 2005 9:16 pm
what shocks/springs is she having? sounds like a good plan in the making
Simon
Post Tue Nov 15, 2005 9:19 pm
I have fitted some Bilsteins with the terra springs for the moment, but will be fitting the cup kit, 60/40
Karan
Post Wed Nov 16, 2005 8:16 am
touring with a 2.7 will be sexual
buster
Post Wed Nov 16, 2005 8:25 am
I know what you mean with the bumpers.You can adjust the up and down at the front by loosening the mounts from inside engine bay for the front of the bumper ,and up and down on the arch side by moving the guides up and down.To get the alignment to the arch itself there isnt much movement but undo the torx bolts (2 off) which are bolted through the front mounts and you can move them in and out but like i said not much.If you can't get enough movement the bumper will have to come off and pack out the mounts.
Simon
Post Wed Nov 16, 2005 8:36 am
Thanks Buster, I will give it a go, the rear bumper is worse.
buster
Post Wed Nov 16, 2005 8:51 am
Rear is pretty much the same,i think theres more in out adjustment for the arch when you undo the 2 torx bolts.Undo the 2 torx bolts but dont take them out,then pull the bumper back as far as it'll go.Set each arch end equal,if theres still too much overlap into the arch when they are both set the same and as far back as possible then tighten the 2 torx bolts and undo the mounts from under the car and inside the boot.Then you'll have to pack them out,thats if of course they arent damaged/crushed ,if they are then thats the cause.
Richy325iTouring
Post Wed Nov 16, 2005 8:17 pm
im already crying
no need to pm my addy
richy325i@ntlworld.com
