m50 engine running cold
japcarkiller
Post Mon Nov 14, 2005 8:15 pm
ok it an m50 engine and its running cold. only gets out of the blue if i sit in traffic. I guess the thermostat is stuck open. ordering the new thermostat tomorrow. Checked my haynes and it doesn't cover the m50. :x So how do i go about changing it?
i bet one of ya knows. share the knowledge guy and gals.
The Scumball.1000miles 1000minutes £1000 car
WWW.SCUMBALL.CO.UK
clicky clicky
Jamesb318is
Post Mon Nov 14, 2005 9:08 pm
i think they're the same as on later engines (m54 etc)
on the front of the engine there should a coolant pipe going to a plastic housing bolted the the front of the head with 10mm's. To get to this you will almost certainly have to remove the fan shroud ( a couple of clips/ screws) and the viscous fan. This has a 32mm opposite thread nut.
The 'stat is in this housing, just remove from head and replace (along with o-ring) (also check stat is the same temperature rating)
Sorry if this is wrong, i can only picture the m52/54 engines, but they are very similar in terms of basic layout
japcarkiller
Post Mon Nov 14, 2005 10:11 pm
thanks dude.
Any one know for certain. there must be some one that knows about the m50.
a few pics would be really cool.
WWW.SCUMBALL.CO.UK
clicky clicky
Post Mon Nov 14, 2005 11:42 pm
Yep, jamesb318iSs description is close enough, although early engines havge a metal stat housing with a gasket rather than an O ring.
japcarkiller
Post Wed Nov 16, 2005 12:14 am
found a cool guide for an e36 m50. the guide is for flushing the system and changing the thermostat.
So my new question is........... Do i have to drain the system b4 i can change the thermostat. or is it just a straight swap job?
WWW.SCUMBALL.CO.UK
clicky clicky
Post Wed Nov 16, 2005 9:54 pm
You don't have to drain the system, but you'll lose a fair bit of coolant anyway, so it would be a good time to drain the coolant and replace it unless it's nearly new.
