i bet one of ya knows. share the knowledge guy and gals.
m50 engine running cold
japcarkiller
ok it an m50 engine and its running cold. only gets out of the blue if i sit in traffic. I guess the thermostat is stuck open. ordering the new thermostat tomorrow. Checked my haynes and it doesn't cover the m50.
So how do i go about changing it?
Jamesb318is
i think they're the same as on later engines (m54 etc)
on the front of the engine there should a coolant pipe going to a plastic housing bolted the the front of the head with 10mm's. To get to this you will almost certainly have to remove the fan shroud ( a couple of clips/ screws) and the viscous fan. This has a 32mm opposite thread nut.
The 'stat is in this housing, just remove from head and replace (along with o-ring) (also check stat is the same temperature rating)
Sorry if this is wrong, i can only picture the m52/54 engines, but they are very similar in terms of basic layout
japcarkiller
thanks dude.
Any one know for certain. there must be some one that knows about the m50.
a few pics would be really cool.
Yep, jamesb318iSs description is close enough, although early engines havge a metal stat housing with a gasket rather than an O ring.
japcarkiller
found a cool guide for an e36 m50. the guide is for flushing the system and changing the thermostat.
So my new question is........... Do i have to drain the system b4 i can change the thermostat. or is it just a straight swap job?
You don't have to drain the system, but you'll lose a fair bit of coolant anyway, so it would be a good time to drain the coolant and replace it unless it's nearly new.
