gearbox rattle when hot
Post Sun May 20, 2012 9:11 pm
Finally put some miles on the turd - 80 mile round trip to Jim's meet yesterday and 250 miles roadtrip to wales today.
Noticed when I got back from Jims and a couple of times today that after a good run when idling there is a rattle from the gearbox which goes as soon as you put the clutch in.
Is this the standard getrag layshaft chatter ?
Never had it before on my other E30's - the box is otherwise quiet in all gears and the shift quality is excellent.
Would a change to ATF fluid help ? Is it one of those things that can be lived with or does it need fixing :roll:
I havent changed the gearbox oil since I had the car and its odds on its the original fluid or if not its still very old
e301988325i
Post Sun May 20, 2012 9:19 pm
I think the change to ATF makes it worse and is to cure poor cold shifting. Regards the rattle I understand all G260's do it and will go on forever like it.
I said:
e30topless said:
lock the wife in there
Post Sun May 20, 2012 9:20 pm
Cheers - thats what I wanted to hear :D
Will just put change the gearbox oil with standard then :thumb:
Kedge
Post Sun May 20, 2012 9:23 pm
Pretty much every E30 i've had does this Rob, nothing to worry about.
Instagram - Kedge85
Post Sun May 20, 2012 9:26 pm
Cheers Dave - its only really noticeable after its been running for a while at speed. As long as its not likely to shat itself I can live with it :D
Post Sun May 20, 2012 9:34 pm
I had this on my sport, its the clutch release bearing, i put a new one in when the engine was out and it went :D
Nothing to worry about though
HairyScreech
Post Mon May 21, 2012 3:54 am
A lot of cars with relatively light crank and flywheel do this, its due to the fluctuations in engine speed causing the input shaft of the gear box to chatter either in the clutch or teeth of the gear.
A rough idle will exaggerate it as mine went totally after fixing a small air leak.
Ajsingh
Post Mon May 21, 2012 7:10 am
My 320i did this, when changing the clutch, the release bearing was replaced and it cured the issue
E30 Crazy!
Post Mon May 21, 2012 6:29 pm
HairyScreech wrote:A lot of cars with relatively light crank and flywheel do this, its due to the fluctuations in engine speed causing the input shaft of the gear box to chatter either in the clutch or teeth of the gear.
That explains a lot then - I know I've got an slight airleak somewhere - just can't find it :x
kam-325i
Post Mon May 21, 2012 7:44 pm
capri_rob wrote: after a good run when idling there is a rattle from the gearbox which goes as soon as you put the clutch in.
Clutch release bearing....or what its called.
SGP
Post Mon May 21, 2012 8:48 pm
Defo, sounds like the thrust bearing.
If it ain't broke..
Fix it till it is :)
