Noticed when I got back from Jims and a couple of times today that after a good run when idling there is a rattle from the gearbox which goes as soon as you put the clutch in.
Is this the standard getrag layshaft chatter ?
Never had it before on my other E30's - the box is otherwise quiet in all gears and the shift quality is excellent.
Would a change to ATF fluid help ? Is it one of those things that can be lived with or does it need fixing
I havent changed the gearbox oil since I had the car and its odds on its the original fluid or if not its still very old
