fuel gauge problems
hammersfan12
Post Thu Apr 26, 2012 1:03 pm
can somebody help, so unless petrol has got that bad lol if my car starts chugging. needs petrol i put 10 in and the light dont even go off. could it be the sender, fuel pump or the gauge on the dash. thanks :)
Grrrmachine
E30 Zone Wiki / Team Member
Post Thu Apr 26, 2012 1:52 pm
I'm really not sure I understand what you're saying, so correct me if I'm wrong:
You put some fuel in and the orange fuel light doesn't go out. What's 10? Ten quid or ten litres? The light should be on if there's less than 10 litres in the tank. If you've filled up and the light is still on, it's likely to be the sender.
http://www.e30zone.net/e30zonewiki/inde ... el_Senders
sunnyr83
Post Thu Apr 26, 2012 4:42 pm
Sorry for the hi jack but I don't think my low fuel light works at all, what's the problem here then. I have gone way past the last line with no light on. Needle also twitches a mm or 2 if i go over a bumpy road.
Any ideas??
Rtaylor2208
Post Thu Apr 26, 2012 4:58 pm
Possibly could be the gauge. I have a similar problem I that the light only comes on way after it has passed the last mark. It looks like the clocks have been changed on mine at some point and it's got the gauge for the larger 60 something litre tank instead of the one for the 53 litre tank.
sunnyr83
Post Thu Apr 26, 2012 6:14 pm
Has it got a brass nut that needs tightening at the back?? Like the temp gauge has.
When I had your cab it had super rare white M dials with colour changing nonsense. Are they still present?
hammersfan12
Post Thu Apr 26, 2012 11:42 pm
Grrrmachine wrote:I'm really not sure I understand what you're saying, so correct me if I'm wrong:
sorry should be more clear lol, yeah put 10quid in it was running out and after i put it in the light didn't go out. where when ive done it befroe just to test it light went out and went up to almost a quater a tank.
Grrrmachine
Post Fri Apr 27, 2012 7:12 am
It all depends on how much is left in the tank. Ten pounds won't buy you 8 litres these days, so you still might not have enough in the tank to make the sender work.
Stop being a tight-arse and brim the tank, to properly test the senders and gauge. Letting the fuel level run that low anyway will cause more serious problems down the line, because the fuel pump will be sucking up all the crud and sand in the bottom of the tank. Then you'll have to buy a new fuel pump.
