325i erratic idle?
cosmic
my 325i idles erratically when warmed up (revs between 700_900 when at idle) fine at all other times ive checked for air leaks and replaced idle control valve its improved matters but not cured it completly any ieas
Taylor325i
- Location: Kilmarnock, Ayrshire, Scotland. Brilliant Red Tech II 325i.
Check the rubber boot thoroughly (between air flow meter and throttle body) as it can be split underneath where you can't see it, letting un-metered air into the engine.
Taylor.
Taylor.
Ant
- Retired Team Member
check the breather pipe under the TB, it runs from the rockerbox to the stub on the side of the body, these are normally toasted by engine heat and split right where you cant see it.
If you cant find any leaks, check the TPS is making contact correctly at idle, and get the idle mix checked, if its lean/rich the car will hunt, the ICV often makes any issues worse as it shuttles to maintain the mapped idle speed.
HTH, keep us posted
HTH, keep us posted
Email FTW
DazzyA
Ant, the does the breather pipe come from left hand side, top of rocker cover and if so should it be clipped as I can pull mine off
easily, also seems to leak a little oil.
cheers
darren
cheers
darren
Pass me the spanner
oze30
same for mine! Leaking oil ( I thought this oil was sposed to go back to the inlet and be burnt thru the combustion process??) and split too!
DazzyA
not sure mine just runs to the cover bolt to the left, pipe dosen't seem long enough to get a clip on it. Where'd everybody go??
[img][img]http://img14.imageshack.us/img14/4751/c ... 6wl.th.jpg[/img][/img]
Pass me the spanner
e30325itourer
there should be a jubilee clip on it to tighten it to the stub on the rocker cover
kenwoir
I have the same problem... Grand when started cold but once she heats up it's up and down between 700-900cosmic wrote:my 325i idles erratically when warmed up (revs between 700_900 when at idle) fine at all other times ive checked for air leaks and replaced idle control valve its improved matters but not cured it completly any ieas
Ant
Sounds like everyone needs a new breather hose
, its a few Ԛ£Ã”šÃ‚£ from the stealer and easily fitted, worth the effort I'd say, if its not the cure its another "maybe" off the list
the breather is vented behind the throttle plate ,any air leak there is unmetered and will cause all sorts of strange running, the cold start enrichment adds more fuel so can mask the symptoms.
nice car Kenwoir !
nice car Kenwoir !
Email FTW
kenwoir
Cheers Ant...ant wrote:
nice car Kenwoir !
Mine's in a dire need of a services once i gt a few days off i'll get it into the workshop and get everything checked and changed on it before winter really sets it
And when everones' sorted out their air leaks, there's always the blue temp. sensor.
