Many Thanks
Wiring Question
Ianb
I have just fitted my m50 and I've managed to reposition the relays and wiring to fit along the bulkhead and put the ECU under the dash, however in doing this I relocated the diagnostic plug ( looks like a C101 with a cover on ) to the passenger side. Linked into this diagnostic plug area of the loom is a short earth that was bolted directly to the battery negative, however I really don't want to run it right back across the bulkhead as space is limited to say the least. Does anyone know if I have to run this all the way back across or can i just earth it to the body ?
( I suspect it is the main earth for the engine loom and i will have to but would appreciate any opinions ? )
Many Thanks
Many Thanks
A proper earth point is favoured, dont just drill a hole and screw it on with a self tapper though, ive seen plenty done like this and it just ends up melting the loom
If you spend some time on it there can be plenty of room in that bulkhead cover -
ross_jsy
Dan, what is the favoured bulkhead cover? Is it the one off an iS?
Ianb
Thanks Dan ( Yet again !)
I'll take that advice ......More fiddling required
randomspeedfreak
i thought it was any 4 pot?ross_jsy wrote:Dan, what is the favoured bulkhead cover? Is it the one off an iS?
Also found on the diesels, full list here -
http://www.realoem.com/bmw/partxref.do? ... showeur=on
Parts 22, 23, 24 here -
http://www.realoem.com/bmw/showparts.do ... g=51&fg=20
21 is the M3 battery tray rear cover, perfect finishing touch
ross_jsy
Cheers Dan
BATTS91
one day my wireing will look like that , and my ecu not in the glovebox haha ,when i can be bothered
With the new MOT test regs. now covering wiring, this day may have to be sooner than you think!BATTS91 wrote:one day my wireing will look like that , and my ecu not in the glovebox haha ,when i can be bothered
It can be done much quicker/easier for a reasonable costBATTS91 wrote:one day my wireing will look like that , and my ecu not in the glovebox haha ,when i can be bothered
