Wiring Question
Ianb
Post Mon Apr 16, 2012 10:21 am
I have just fitted my m50 and I've managed to reposition the relays and wiring to fit along the bulkhead and put the ECU under the dash, however in doing this I relocated the diagnostic plug ( looks like a C101 with a cover on ) to the passenger side. Linked into this diagnostic plug area of the loom is a short earth that was bolted directly to the battery negative, however I really don't want to run it right back across the bulkhead as space is limited to say the least. Does anyone know if I have to run this all the way back across or can i just earth it to the body ? :? ( I suspect it is the main earth for the engine loom and i will have to but would appreciate any opinions ? )
Many Thanks
Post Mon Apr 16, 2012 10:59 am
A proper earth point is favoured, dont just drill a hole and screw it on with a self tapper though, ive seen plenty done like this and it just ends up melting the loom :o
If you spend some time on it there can be plenty of room in that bulkhead cover -
ross_jsy
Post Mon Apr 16, 2012 11:23 am
Dan, what is the favoured bulkhead cover? Is it the one off an iS?
Ianb
Post Mon Apr 16, 2012 11:32 am
Thanks Dan ( Yet again !) :cool: I'll take that advice ......More fiddling required :eek:
randomspeedfreak
Post Mon Apr 16, 2012 12:10 pm
ross_jsy wrote:Dan, what is the favoured bulkhead cover? Is it the one off an iS?
i thought it was any 4 pot?
Post Mon Apr 16, 2012 12:49 pm
Also found on the diesels, full list here -
http://www.realoem.com/bmw/partxref.do? ... showeur=on
Parts 22, 23, 24 here -
http://www.realoem.com/bmw/showparts.do ... g=51&fg=20
21 is the M3 battery tray rear cover, perfect finishing touch 8)
ross_jsy
Post Mon Apr 16, 2012 12:51 pm
Cheers Dan 8)
BATTS91
Post Tue Apr 17, 2012 10:36 pm
one day my wireing will look like that , and my ecu not in the glovebox haha ,when i can be bothered
Post Tue Apr 17, 2012 10:42 pm
BATTS91 wrote:one day my wireing will look like that , and my ecu not in the glovebox haha ,when i can be bothered
With the new MOT test regs. now covering wiring, this day may have to be sooner than you think!
Post Tue Apr 17, 2012 10:53 pm
It can be done much quicker/easier for a reasonable cost :wink:
