318is more cc?
samuraibaz
Hi all
Does anyone know how i can up the M42 from 1800cc without spending buckets of cash as i like the high revving 4 cylinder engine?
BATTS91
mehh dude i might aswell be the first to say so here goes ,hell of alot cheaper and better to go m50/52
Grrrmachine
- E30 Zone Wiki / Team Member
That's simply not going to happen.samuraibaz wrote:without spending buckets of cash
cee
Best bet would be M44 parts from an e36. But you're not looking at a lot of difference to be honest, unless you start making drastic changes you won't get much of a power difference. Highest bhp I've seen a naturally aspirated M42 put out without major rework is about 160.
1990 Sterlingsilber 318iS - 146 bhp / 192 Nm
e30kev
just turbo it or drop a real engine in with the correct amount of cylinders
cee
I was always adamant that 4cyls were better too until I did the research, in reality, until BMW make a large capacity l4, the only option for more power is an m20 or m50.
kevo
I'm considering selling my m42 engine from my rally car if you are interested? it has a set of cat cams, it's been fully rebuilt with proof etc around 2000 miles ago, has three angle valve seats cut in it, has a big bore throttle body and a fully remapped ecu (not just a chip). it also has a lightweight flywheel on it too.
I only offered as all the parts are there ready built up which is about as far as you'd really want to go without boring out the cylinders etc which isn't really too viable financially bhp/£.
having said that I'll be looking to stick an m52 in it as i've been so impressed with the one in my road car, but it is a bit heavier over the nose than the m42.
Kev
Kev
cee
What kind of specs are you getting from it?kevo wrote:I'm considering selling my m42 engine from my rally car if you are interested? it has a set of cat cams, it's been fully rebuilt with proof etc around 2000 miles ago, has three angle valve seats cut in it, has a big bore throttle body and a fully remapped ecu (not just a chip). it also has a lightweight flywheel on it too.
Kev
kevo
I haven't had it on the rollers, but i think 150-160 is a reasonable assumption although this is based on a guess so isn't a fact. the cams are supposed to bring 10-15bhp or so the ecu remap should bring about the same, the engine is freshly rebuilt and the head skimmed so the compression is marginally up on standard and the big bore throttle body is supposed to add a bit too, all that on top of 136bhp from factory, so while i don't have a figure it goes pretty damn well lol. especially when it's mated to a shortened gearbox and a 4.45 diff and revs to 7k and tops out at 105mph in fifth. play.
cee
Sounds good. If I didn't need an economical engine I'd be tempted
kevo
http://www.bmw-rallying.co.uk/viewtopic ... &start=105
it does 30mpg on the way to a rally.
but 20 on it lol
but 20 on it lol
cee
Wow, not too bad!
kevo
my car is lightened though, but then it's short geared too so i suppose it compensates for it. i think in all honestly it would be okay as an everyday runner, although the cams idling wouldn't impress the missus lol
mwggriffiths
A V8?e30kev wrote:just turbo it or drop a real engine in with the correct amount of cylinders
1990 318iS, 1998 E36 328i Touring, 2001 740i Sport, 1971 Range Rover
318isPMK
