318is more cc?
samuraibaz
Post Thu Apr 12, 2012 12:09 am
Hi all
Does anyone know how i can up the M42 from 1800cc without spending buckets of cash as i like the high revving 4 cylinder engine?
BATTS91
Post Thu Apr 12, 2012 12:47 am
mehh dude i might aswell be the first to say so here goes ,hell of alot cheaper and better to go m50/52
Grrrmachine
E30 Zone Wiki / Team Member
Post Thu Apr 12, 2012 6:25 am
samuraibaz wrote:without spending buckets of cash
That's simply not going to happen.
cee
Post Fri Apr 13, 2012 5:52 pm
Best bet would be M44 parts from an e36. But you're not looking at a lot of difference to be honest, unless you start making drastic changes you won't get much of a power difference. Highest bhp I've seen a naturally aspirated M42 put out without major rework is about 160.
1990 Sterlingsilber 318iS - 146 bhp / 192 Nm
e30kev
Post Fri Apr 13, 2012 6:26 pm
just turbo it or drop a real engine in with the correct amount of cylinders :D
cee
Post Fri Apr 13, 2012 6:49 pm
I was always adamant that 4cyls were better too until I did the research, in reality, until BMW make a large capacity l4, the only option for more power is an m20 or m50.
kevo
Post Fri Apr 13, 2012 7:14 pm
I'm considering selling my m42 engine from my rally car if you are interested? it has a set of cat cams, it's been fully rebuilt with proof etc around 2000 miles ago, has three angle valve seats cut in it, has a big bore throttle body and a fully remapped ecu (not just a chip). it also has a lightweight flywheel on it too.
I only offered as all the parts are there ready built up which is about as far as you'd really want to go without boring out the cylinders etc which isn't really too viable financially bhp/£.
having said that I'll be looking to stick an m52 in it as i've been so impressed with the one in my road car, but it is a bit heavier over the nose than the m42.
Kev
cee
Post Fri Apr 13, 2012 7:15 pm
kevo wrote:I'm considering selling my m42 engine from my rally car if you are interested? it has a set of cat cams, it's been fully rebuilt with proof etc around 2000 miles ago, has three angle valve seats cut in it, has a big bore throttle body and a fully remapped ecu (not just a chip). it also has a lightweight flywheel on it too.
Kev
What kind of specs are you getting from it?
kevo
Post Fri Apr 13, 2012 7:55 pm
I haven't had it on the rollers, but i think 150-160 is a reasonable assumption although this is based on a guess so isn't a fact. the cams are supposed to bring 10-15bhp or so the ecu remap should bring about the same, the engine is freshly rebuilt and the head skimmed so the compression is marginally up on standard and the big bore throttle body is supposed to add a bit too, all that on top of 136bhp from factory, so while i don't have a figure it goes pretty damn well lol. especially when it's mated to a shortened gearbox and a 4.45 diff and revs to 7k and tops out at 105mph in fifth. play.
cee
Post Fri Apr 13, 2012 7:57 pm
Sounds good. If I didn't need an economical engine I'd be tempted :(
kevo
Post Fri Apr 13, 2012 8:13 pm
cee
Post Fri Apr 13, 2012 8:16 pm
Wow, not too bad!
kevo
Post Fri Apr 13, 2012 8:21 pm
my car is lightened though, but then it's short geared too so i suppose it compensates for it. i think in all honestly it would be okay as an everyday runner, although the cams idling wouldn't impress the missus lol
mwggriffiths
Post Sun Apr 15, 2012 9:37 pm
e30kev wrote:just turbo it or drop a real engine in with the correct amount of cylinders :D
A V8? winkeye
1990 318iS, 1998 E36 328i Touring, 2001 740i Sport, 1971 Range Rover
318isPMK
Post Sun Apr 15, 2012 10:21 pm
I think you should appreciate it for what it is or sell it and buy and 325 it was never meant to be what you want it to be... Listen to me getting all sensible!
