me again lol , my heaters dont blow out hot on my m50 conversion ive checked the pipes there correct , from head to bottom of matrix ,
so the only rhing i can think of is heater control valve not opening , this has been recently changed for a 2nd hand unit from a zoner as mine cracked , is there some basic electrics i can check to make sure its openin and how ??? thanks
heaters ?
BATTS91
BATTS91
wiki to the rescue just read it shall try tomoz , that might make grrr abit happy !!!
Grrrmachine
- E30 Zone Wiki / Team Member
BATTS91
i see your putting alot of time into the wiki , thus the sigh from you i see earlier lol
Grrrmachine
Nah, it's not my time that bothers me, it's just the attitude of "quick, post a question" rather than "quick, search for an answer."
I know the forum search is daunting, and I know the Wiki needs more tweaking so make it user-friendly, but when there's a question about Lights and there's a big box on the front page of the Wiki called Lights, I can normally tell someone's being a teeny bit lazy.
Let me know how you get on with the Heater bit, and I'll clean up the Heater page if it's confusing.
BATTS91
wiki is clear as bells for my problem, i think its just a case of people forgetting theres a wiki to use (edit, including me !!) ,fookin handy tho good job on the hard work
, i unplugged the thermostat n took it for a drive to get hot, but no heat so i now assume the 2nd hand stat i bought is fooked aswell ,better than having a wet carpet like the last one i spose :/
?? How did you 'unplug' the thermostat?BATTS91 wrote: , i unplugged the thermostat n took it for a drive to get hot, but no heat so i now assume the 2nd hand stat i bought is fooked aswell ,better than having a wet carpet like the last one i spose :/
BATTS91
heater matrix thermostat has a 2 pin plug on top of it
BATTS91
or you could also call it ,heater control valve
You can only call it a heater control valve - it's not a thermostat of any description.
The default position of the valve is open when disconnected, and I doubt if this is your problem.
If you're sure the pipes are the right way around, I suspect you have a partial airlock (remove top heater hose to release), the matrix is partially blocked, or the cable from the heat control to the heater box has a problem, and isn't moving the blender flap to full hot.
