Mainfold to down pipe gasket
sharky
Hi
Does anyone know the part n.o for the gasket that goes in between the manifold and down pipe on a 1990 325 cab.
The gasket I have has 4 stud bolt holes as the mainfold has 4 studs and the down pipe has 4 hole for the studs.
BMWFANS and REALOEM only show the 3 stud hole gaskets and part numbers.
kam-325i
sharky
Yeah like that, is that for 325i ?
Sanchez
Nope but possibly early 320isharky wrote:Yeah like that, is that for 325i ?
kam-325i
No its not, is for a 318i......sharky wrote:Yeah like that, is that for 325i ?
i dont think i have come across a 325i OEM manifold that has four studs on the exhaust mating face.......
sharky
Thought it was, was wondering also if the 318i gasket was the same size as the 4 stud one on my 325i, my gasket though has a diamond shape outer profile.
kam-325i
bottom left of picture
kam-325i
thats from the 318i M40 gasket set.....sharky wrote:Oh yes that is the one.
http://www.realoem.com/bmw/showparts.do ... g=18&fg=05
This is for an '88 325i Touring
IIRC even though the photo looks wrong ( i.e 2 x triangular shaped gaskets ) if you order 1 of the gaskets ( number 2 ) 18301711969 this is what you need and the correct gasket with the 4 bolt holes will be supplied - ive ordered one based on this and the dealers supplied the right one first time.
Obviously put your vin number into realoem to confirm for your car - the above is for a 2 piece system with no cat - I believe the 3 piece system uses a different gasket.
18301711969 is spot on for a 2 piece which your car should have. Rob is right.
I've bought a couple for my 89 325i convertible over the years and thats the number on the invoices.
gaszman
- E30 Zone Meets/Events Team
i have a 318i gasket here bud
sharky
Cheers Gazman, have already ordered a M40 318i gasket of ebay for £4, if it does not fit I will have to get the proper part 18301711969 which appears to be about £20.
