water pump
xavier
Post Wed Mar 07, 2012 2:34 am
Has anyone had a water pump start to go and make rattling noises?
Post Wed Mar 07, 2012 6:49 am
Not so much rattling but screeching and generally strange noises. I had to strip the front of my M20 down to find it. A seized pump that was kicking and screaming against turning when the engine was running.
Post Wed Mar 07, 2012 9:01 am
Can rattle initially if the bearing cage has broken up and the grease has gone, but it won't last long!
Jos
Post Wed Mar 07, 2012 9:51 am
Mine did that, bearing cage collapsed and was squirting water out the shaft!
Slacken the belt off and give it a wiggle, if it does, replace.
'94 e36 tree climber
