manual box conversion
adam-325i
just a quick one im looking at converting my e30 to a manual is it simple job the engine and box are on a bench already so i can get into the bay and makes it easy getting the box apart and back together just some advise reli please
it's easy enough,the brake bar is a fiddle when fitting the manual pedal box.
you'll need a spigot bearing not sure what size as there are two types so check 1st.
you'll need a flywheel,clutch,manual pedal box with master cylinder and fluid pipe to fluid bottle.
the metal pipe across bulkhead,slave cylinder and hose,manual box and shifter ,propshaft,
think that's it ....
what engine is it ?i have loads of 4-pot conversion parts or can help with some of the list ..
+ a yard full of scrap turds
Grrrmachine
- E30 Zone Wiki / Team Member
adam-325i
its for a 2.5 bud iv got a mate thats gonna swap me for my box for his kit so its not to bad just wanted advise on fitting reli
