Fans always running.
Corrado1441
Post Wed Feb 15, 2012 10:13 pm
Hi on my 1989 E30 325i Sport, as soon as I start the car the fan runs constant, also noticed after a drive the temp gauge does not move off the blue line even though engine is warm ??
chh137
Post Wed Feb 15, 2012 10:22 pm
Viscous coupling?
kam-325i
Post Wed Feb 15, 2012 11:09 pm
Corrado1441 wrote:Hi on my 1989 E30 325i Sport, as soon as I start the car the fan runs constant,
its meant too....viscous coupling.....
Post Wed Feb 15, 2012 11:13 pm
Dos the fan roar if you rev the engine? The fan should always be turning on an E30, but at a much slower speed than the engine at anything above idle.
If the bearing on a viscous fan coupling has seized, the roar from the fan at medium/high revs will be unmistakeable.
Even if the fan coupling bearing has seized it shouldn't have much effect on the engine temp. I'd be looking at the thermostat in relation to the low temp. problem.
Grrrmachine
E30 Zone Wiki / Team Member
Post Thu Feb 16, 2012 5:24 am
e301988325i
Post Thu Feb 16, 2012 10:27 am
Corrado1441 wrote:also noticed after a drive the temp gauge does not move off the blue line even though engine is warm ??
Can you confirm the radiator is hot, not warm with the gauge in the blue?
Even when thermostats die and cause overcooling a motorway drive should still get the car up to temperature, does your needle move towards the centre in that situation?
I'm thinking brass nut on the back of the cluster may have rattled loose.
I said:
e30topless said:
lock the wife in there
Post Thu Feb 16, 2012 1:28 pm
That would make the gauge read higher than it should, not lower.
Corrado1441
Post Thu Feb 16, 2012 8:51 pm
I've been told the 2 sensors, brown and blue ones go faulty, might replace them along with the thermostat.
kam-325i
Post Thu Feb 16, 2012 9:02 pm
Blue temp sensor is for the ECU....
