Wiring for SUB.
e30kid6
Post Tue Jan 31, 2012 8:08 am
Hello,
Right I was planning on wiring up my sub yesterday but I soon realised that I couldn't find any clear sort of hole at the rear of the engine bay where I could stick a couple of wires through to my battery. In my previous cars the battery has been on the passenger side, so i'm not too sure where to look. I've seen where the main loom goes through, but I can't see that being any help because you cant get to it from the inside of the car. Any help please? :cry:
macas
Post Tue Jan 31, 2012 8:29 am
Trace where the waters coming in on the bulkhead and you will find a nice big hole!if your lucky you will be be spoilt for choice! :D
Post Tue Jan 31, 2012 9:01 am
e30kid6 wrote: I've seen where the main loom goes through, but I can't see that being any help because you cant get to it from the inside of the car. Any help please? :cry:
It's easily accessible behind the glovebox, and is provided with cut out sections for extra wiring.
Why can't you access it?
e30kid6
Post Tue Jan 31, 2012 12:23 pm
hmmm this loom i was looking at went in behind the battery and into the dash behind the clocks, I couldnt get to that. I didn't manage to see anything behind the glove box, but then again I didn't think there would be anything there :?
Post Tue Jan 31, 2012 1:07 pm
e30kid6 wrote:hmmm this loom i was looking at went in behind the battery and into the dash behind the clocks,
That's the engine loom going to the ECU - such is the design of the E30 that the engineers specified that the ECU should be inside the cabin, away from the elements, unlike on later models and other makes. There's no provision for any other wires to go through where that goes though.
The body loom passes through where I said, through a large grommet, around 3 1/2" across, that has cut out sections for additional wiring.
e30kid6
Post Tue Jan 31, 2012 1:15 pm
Okay thanks a bunch. I'll have another go tonight. :D
e30kid6
Post Thu Feb 02, 2012 7:33 am
Thanks for that, found it pretty much straight away. Wish I looked there first time round! :D
