Right I was planning on wiring up my sub yesterday but I soon realised that I couldn't find any clear sort of hole at the rear of the engine bay where I could stick a couple of wires through to my battery. In my previous cars the battery has been on the passenger side, so i'm not too sure where to look. I've seen where the main loom goes through, but I can't see that being any help because you cant get to it from the inside of the car. Any help please?
Wiring for SUB.
e30kid6
Hello,
macas
Trace where the waters coming in on the bulkhead and you will find a nice big hole!if your lucky you will be be spoilt for choice!
It's easily accessible behind the glovebox, and is provided with cut out sections for extra wiring.e30kid6 wrote: I've seen where the main loom goes through, but I can't see that being any help because you cant get to it from the inside of the car. Any help please?
Why can't you access it?
e30kid6
That's the engine loom going to the ECU - such is the design of the E30 that the engineers specified that the ECU should be inside the cabin, away from the elements, unlike on later models and other makes. There's no provision for any other wires to go through where that goes though.e30kid6 wrote:hmmm this loom i was looking at went in behind the battery and into the dash behind the clocks,
The body loom passes through where I said, through a large grommet, around 3 1/2" across, that has cut out sections for additional wiring.
e30kid6
e30kid6
