Gas fitters & gas axe'ers
Post Sat Jan 28, 2012 11:11 pm
Picked up this 100 litre tank for a bargain £20 the other day :D
To replace the 57 litre in there, which is tight, will take some chopping!
Cant wait for some long range action 8)
nickso
Post Sat Jan 28, 2012 11:31 pm
No plans to carry anything but gas in the boot then? :)
'88 e30 328i M52 track bint.
Post Sat Jan 28, 2012 11:36 pm
looks a tight fit, some spare wheel well action needed here? :eek:
Post Sat Jan 28, 2012 11:52 pm
DanThe wrote:Cant wait for some long range action 8)
Still well down on the180 litres of tank that my E34 had when I bought it! A range of about 900 miles, plus the tank of petrol.
Two cylinder tanks in the boot, leaving just about room for a briefcase. I rem.oved the 100 litre one, leaving just the 80, giving a range of about 300 miles
Post Sat Jan 28, 2012 11:54 pm
Loads of action needed! Ive got a steel petrol tank lined up to cut n shut as most of it is under the wheel well.
Then its either remove the well, plate the floor and bolt the tank to the underside, or remove the well and replace with a larger one.
Mig marathon is on the cards either way, should be good for 400 miles with this baby :D
Dezzy
CR24v it's a lifestyle
Post Sun Jan 29, 2012 12:26 am
All you need now is a big tank at home for keeping warm!
Post Sun Jan 29, 2012 12:53 am
Is that where you were going when I spoke to you?? :mad:
Post Sun Jan 29, 2012 7:01 pm
Im no office jockey Brian, I need a boot for proper things like engines and what not :D
If I could get away with a big tank id have one like a shot, propane FTW 8)
leeparkes
Post Sun Jan 29, 2012 7:02 pm
Its a big un. :)
How much is gas nowadays?
Post Sun Jan 29, 2012 7:14 pm
leeparkes wrote: How much is gas nowadays?
64p per litre at my local, everywhere else thats easy to find is 8 - 10p more. Did a 240 odd mile run last weekend for £31 8)
leeparkes
Post Sun Jan 29, 2012 7:18 pm
8)
Post Sun Jan 29, 2012 7:38 pm
78p at my local BP!!!! Although i can get it for 70p at a Flowgas place 3 miles further away.
I've got a spare wheel well here that I cut from (IIRC) an E28, and a tank to fit it that holds around 65 litres that I was going to fit into my red touring. Unfortunately it's meeting with a flying Porker happened before I could get the cutter and MIG into action.
Post Mon Jan 30, 2012 9:17 am
leeparkes wrote:Its a big un. :)
~70-73p/L here..
