Could this be down to it being mounted with cable ties to the shell
Noisy electric fan.
Green
When my fan kicks in (e36 air con fan) it make a bit of a racket. The fan noise is generally loud and it vibrates the inside of the car as well
kam-325i
Sounds like one of the balancing clips have come of.
Green
A little further info please?
kam-325i
Like a car wheel, some fan blades need to be balanced, to stop vibraiton.
most plastic fan blades will have a little metal clip, to act a weight, to balance the baldes, these can come off, causing vibration and eventual bearing faliure.
these clips can be found on the edge of the blade.
