Noisy electric fan.
Green
Post Fri Jan 06, 2012 7:29 pm
When my fan kicks in (e36 air con fan) it make a bit of a racket. The fan noise is generally loud and it vibrates the inside of the car as well 8O
Could this be down to it being mounted with cable ties to the shell :o:
kam-325i
Post Fri Jan 06, 2012 7:57 pm
Sounds like one of the balancing clips have come of.
Green
Post Sat Jan 07, 2012 2:29 pm
A little further info please?
kam-325i
Post Sat Jan 07, 2012 3:07 pm
Like a car wheel, some fan blades need to be balanced, to stop vibraiton.
most plastic fan blades will have a little metal clip, to act a weight, to balance the baldes, these can come off, causing vibration and eventual bearing faliure.
these clips can be found on the edge of the blade.
