fitting seal to my lsd
321gazza
Post Thu Jan 05, 2012 8:30 pm
have purchased an lsd diff from a tech1 325i, want to fit new oil seals to the drive shaft end of the diff, is it simply a case of pulling out the seals and pushing the new one in and also is it the same with the front seal with the metal cover were the prop bolts onto, pineon oil seal i think its named.
Supafly
Post Fri Jan 06, 2012 3:10 am
The output shaft seals are easy enough, check the lsd rebuild threads and it's all pictured. It was a long while ago when I changed mine, the output shafts just pop out, you might need to unbolt the caps to get at the seals....
As for the input seal, don't touch it unless you need to, from my reading on the subject it will need some careful setting up afterwards to maintain the pinion settings.
Post Fri Jan 06, 2012 9:26 am
As above - output seals easy; input seal - don't touch unless you know exactly what you're doing.
321gazza
Post Fri Jan 06, 2012 10:41 am
Ok many thanks, nothing to reset if i take output shaft caps off to replace the seals.
Supafly
Post Sat Jan 07, 2012 6:31 pm
No, easy peasy. Just make sure everything goes back together in the same order.
