Seat differences??
Cloggy Saint
Post Sun Jan 01, 2012 2:34 pm
I've just rebuilt my driver's seat using new material and a diffferent base. Everything looks good but after fitting it I've discovered that the bar to adjust the back/forward position of the seat is completely different from the original. It kinks sharply to the left as you look down on it, meaning it is positioned directly under the fire extinguisher and can't be used :cry: . I've done a few seats before and have never seen this. I'd prefer to try and fit the original adjuster bar than put all the foam/cloth on to a different base but I can't see how it can be done. Anyone shed some light on this??
jonny323i
Post Sun Jan 01, 2012 3:42 pm
any chance of a pic mate and i will check it against mine as they will come out of the car in the next day or so
Touring for life
Cloggy Saint
Post Sun Jan 01, 2012 4:28 pm
Can't do a pic now, the seat is in the car. I think swapping the runners around would be the best bet as the adjustment lever doesn't look removeable.
jonny323i
Post Mon Jan 02, 2012 10:45 am
thats the underside of the old passenger side frame i had left over until i get the other seats out i can only pressume the drivers side is the same but opposite hand
Touring for life
Cloggy Saint
Post Mon Jan 02, 2012 11:26 am
Here's the offending article on the right. The enlarged kink makes the handle impossible to use :mad: .
jonny323i
Post Mon Jan 02, 2012 11:32 am
that is a big difference.
It shouldnt be too difficult to remove the entire runner and change it over
Touring for life
Cloggy Saint
Post Mon Jan 02, 2012 11:33 am
Yep, all done now, time for the second fit. It seems strange that there are 2 different types of lever, what's the point??
