Anyone know where the pollen filter for a 318Ti compact is please?
1999 with air con.
318Ti pollen filter
fixedwheelnut
Without A/C it could be under the scuttle panel two small ones cover the heater air intake.
With A/C in the heater box accessed from the drivers side underdash, it folds so that it can go inbetween the space by the steering column.
So is that the under-panel down and can you see it ?fixedwheelnut wrote:Without A/C it could be under the scuttle panel two small ones cover the heater air intake.
Is that the rectangular one?
it's a bit of a mission to change these if you haven't done it before,
Drop by Mart i will sort it
e30topless wrote:it's a bit of a mission to change these if you haven't done it before,
Do my best Steve.
