Fritsbitz manifold
badger88
Post Sat Dec 17, 2011 5:08 pm
What is rong with the fritzbits manifold compared to the btb1, i am looking to buy 1 as i carnt afford the btb price. :(
"IF It's not right it's wrong"
sweep
Post Sat Dec 17, 2011 5:16 pm
These are good manifolds i run a btb one and a frit's one on my other car
Post Sat Dec 17, 2011 6:38 pm
Not proven. Designed for the M50, so it's either too big for that or too small for the S50..
badger88
Post Sun Dec 18, 2011 11:55 am
ok will the fritsbits manifold for the s50 conversion be ok and not foul? :D
Post Sun Dec 18, 2011 6:58 pm
Fritz system is 60mm twin pipes all the way through, I think the manifold sections are either the same or slightly larger, not smaller.
I will also point out the M/S50 setup is made by a different company to the 'other' fritz exhausts which have been known to crack/blow baffles etc in the past
Post Sun Dec 18, 2011 7:11 pm
I was referring to the manifold.. If it works for one it wont the other, as the port sizes are very different.
