Fritsbitz manifold
badger88
What is rong with the fritzbits manifold compared to the btb1, i am looking to buy 1 as i carnt afford the btb price.
"IF It's not right it's wrong"
sweep
These are good manifolds i run a btb one and a frit's one on my other car
- Homo Hair
Not proven. Designed for the M50, so it's either too big for that or too small for the S50..
badger88
ok will the fritsbits manifold for the s50 conversion be ok and not foul?
Fritz system is 60mm twin pipes all the way through, I think the manifold sections are either the same or slightly larger, not smaller.
I will also point out the M/S50 setup is made by a different company to the 'other' fritz exhausts which have been known to crack/blow baffles etc in the past
- Homo Hair
I was referring to the manifold.. If it works for one it wont the other, as the port sizes are very different.
