car wont start?
deanocool
Post Thu Dec 15, 2011 2:12 pm
drove to work the other day with my M50 absolutely fine. went to start up and the car starts then cuts out almost immediately. if i unplug the maf it ticks over but very rough :? ive got a new maf but its still exactly the same, starts then cuts out. cant think what could go so suddenly when it was running smooth a few hours before. crank sensor? any ideas? :evil:
HairyScreech
Post Thu Dec 15, 2011 2:21 pm
massive air leak/split hose?
dead maf sensor?
deanocool
Post Thu Dec 15, 2011 2:22 pm
ive changed the maf - no difference. cant see a split hose either. it was fine when i turned it off then it wouldnt start when i was going home. petrol and matches time! :x
mrLEE30
Post Thu Dec 15, 2011 3:38 pm
You might try posting in the technical section, that normally works, moved for you.
deanocool
Post Thu Dec 15, 2011 3:41 pm
cheers dude! just sorted it anyway! the large vacuum pipe under the middle 2 inlet pipes had dislodged because the clips are shot. it hadnt come out totally but obviously enough to clonk the vac supply. pushed it back in and bobs your uncle! need to sort out securing it next! :D :D :D
