REAR BRAKE CALIPER PISTON SEALS !!!
E30cabrioman
Post Mon Oct 31, 2005 11:53 pm
Anyone no how much these are and maybe a part number ??
and are they easy fit...does piston need to be out or in when fitted????
all comments welcome thank you...... :D :D :?
325i Cab
E39 V8
Templ8e30
Post Tue Nov 01, 2005 11:03 am
The rear caliper rebuild kit is part number 34211153194 and costs about Ԛ£8. You'll need 2 kits for the car.
The kit comprises: piston seal,dust seal,circlip.
The caliper needs to be properly stripped and cleaned with the piston out to fit the kit.
Relatively easy to fit but time consuming to do it carefully, the inside of the caliper and the piston need to be spotless
Cheers,
Iain T
2007 Mazda 6 2.0 estate
E30cabrioman
Post Tue Nov 01, 2005 2:53 pm
I have calipers off and had old seals out(one side was split) thanks for part number and info was not sure if piston needed to come out for refit
cheer for info
Stu :D :cool:
325i Cab
E39 V8
