Post
Tue Nov 01, 2005 11:03 am
The rear caliper rebuild kit is part number 34211153194 and costs about Ԛ£8. You'll need 2 kits for the car.
The kit comprises: piston seal,dust seal,circlip.
The caliper needs to be properly stripped and cleaned with the piston out to fit the kit.
Relatively easy to fit but time consuming to do it carefully, the inside of the caliper and the piston need to be spotless
Cheers,
Iain T
2007 Mazda 6 2.0 estate
