hi
i was looking for a price for the following parts to rebuild my m20 b25
con rod bearing shells (standard)
main bearing shells (standard)
piston rings (standard)
top end gasket set (head, inlet, exhaust)
sump gasket
2no. dowels that locate the head onto the block
injector seals
front and rear crankshaft oil seals
intermediate shaft seal
timing belt
tensioner
water pump
324 td oil pump
my email address is william@quinnpiling.com
thanks
Willy
m20 rebuild parts price please
Cotswoldbmw
Hi Willy. Thanks for youe enquiry. We will need the last 7 digits of chassis no and also the colours marked on all bearings and sizes stamped on them to. Also any part numbers off them. Thanks.
regards
Paul.
regards
Paul.
Cotswold BMW Parts
01242 335365
PayPal? - No Problem
Just send the amount quoted as a gift to partscheltenham@cotswoldgroup.com, along with your name, reference number, delivery address and contact telephone number.
01242 335365
quinn_656
hi paul
the engine im building is a 2.7 engine starting out with a 325i sport engine with a 525e crank and rods the engine is going into an e21 323i so the chassis no. wont be misleading
however the parts that i require should be the same as my mtec1 325i sport of which the last 7 digits are as follows:
0 858 273
there doesnt appear to be any colour or any referance to a colour on the existing bearings however the no.s stamped on the bearings are as follows:
connecting rod bearings
1284 849 & 850 an SK logo with 8578 Sd is also present
it appears that blue is for the top and red for the bottom that would mean i would require 6 blue and 6 red but i cant confirm this
the main bearing shells are still inside the block which is at the machine shop so i dont have access to it at the minute but i know that they will be the standard bearings
the pistons are standard sk 83.98mm
thanks
Willy
0 858 273
thanks
Willy
Cotswoldbmw
Morning Willy. Stuart has sent an email with the quotes on. Thanks.
regards
Paul.
regards
Paul.
Cotswold BMW Parts
01242 335365
01242 335365
