Rtaylor2208
Post
Wed Dec 07, 2011 9:34 pm
Finally got round to having a look at why the drivers door wont lock. It looks like its been a problem in the past and some eejit removed all the central locking actuators
Anyway I think the lock barrel is buggered. I have read that you can buy a lock repair kit to fix some things but will it fix the problem below.
Pictures are of the barrel in the locked position.
Uploaded with
ImageShack.us
Post
Wed Dec 07, 2011 10:16 pm
There's a fair bit of wear in the L shaped piece (which is part of the kit).
What else am I supposed to see, or am I being thick?
Barx325i
Post
Wed Dec 07, 2011 10:21 pm
it's an option to remove the tumblers, inspect them and presuming they're fine, rehome them in a known good barrel. I haven't done this, but it can't be an excessively difficult a job
gooner1
- Out humping Reindeer
Post
Thu Dec 08, 2011 5:27 am
Rtaylor2208 wrote:Finally got round to having a look at why the drivers door wont lock. It looks like its been a problem in the past and some eejit removed all the central locking actuators
Uploaded with
ImageShack.us
Would the Lock not still work with the actuators removed, just not the Central Locking part.
Rtaylor2208
Post
Thu Dec 08, 2011 9:25 am
When turning the lock it goes so far then the arm bit seems to get to a point where it flips open like the 2nd picture above.
It manages to push the lever inside the door up to unlock but not down to lock (think thats the right way round).
Bristol_Jer
Post
Thu Dec 08, 2011 10:11 am
Rtaylor2208 wrote:When turning the lock it goes so far then the arm bit seems to get to a point where it flips open like the 2nd picture above.
Mine does exactly the same thing as this, I usually lock and unlock the car from the boot lock!
Rtaylor2208
Post
Thu Dec 08, 2011 12:25 pm
No central locking to unlock from the boot unfortunatly, loads of central locking parts missing as some previous fud of an owner removed them all.
powelly
Post
Thu Dec 08, 2011 12:50 pm
I'll bet if you strip that down the L shaped bit is broken.
Le Mans Classic 2006
Rtaylor2208
Post
Thu Dec 08, 2011 1:27 pm
Thanks powelly, I'll stip it down following the wiki before buying a repair kit.
