HEADLAMPS WONT TURN OFF
wez201178
Post Mon Nov 28, 2011 11:14 am
HELLO ALL,my bloody headlamps on low beam will not go off even with keys out,this only started last night,please help.
Post Mon Nov 28, 2011 12:54 pm
Pull out relay K4. If this turns them out, check whether it clicks as you pull it out and push it in.
wez201178
Post Mon Nov 28, 2011 3:36 pm
Well mate i have to say thankyou very much,took relay out and they went of,put it back in and they stayed of,back to normal,cheers fella.
Post Tue Nov 29, 2011 12:30 am
Open up the relay, and check that deposits haven't built up on the contacts. If so, file them flat with a nail file. Never use sandpaper.
HairyScreech
Post Wed Nov 30, 2011 12:12 am
Brianmoooore wrote:If so, file them flat with a nail file. Never use sandpaper.
why?
Post Wed Nov 30, 2011 12:16 am
Particles of the grit get embedded in the contacts.
HairyScreech
Post Wed Nov 30, 2011 12:38 am
yes good point, same reason you have to be careful not to wire brush alu to clean it before welding, if you do then its a stainless brush or bust.
Barx325i
Post Wed Nov 30, 2011 12:57 am
brass brush on plugs...
