M40 - m50 engine swap wiring guide?
be11
Post Sun Nov 27, 2011 5:08 pm
I need a wiring guide to mate my e34 m50 engine loom onto the plug on my 1.6 m40 loom.
I presume I'm gonna need some 6 cylinder clocks too?
I have found Diagrams for e30s that were originally 6 cylinder but none for 4 pots.
Cheers guys.
Post Sun Nov 27, 2011 6:25 pm
Exactly the same, except that your four pot body loom won't have the oil level sensor wires.
Check out my 'sticky' "wiring warning" at the top of the engine swaps forum, re. pin 20.
If you change the clocks for six cylinder ones, you will make the tacho. read correctly, but mess up the fuel gauge (unless your car is a touring.) Just change the coding plug on the lower right front face of the clocks.
be11
Post Sun Nov 27, 2011 7:32 pm
Cheers dude. The car is a touring
Also wanna know if I need to change the fuel pump on this conversion? I am assuming so, can I use one out of the donor e34?
eko
Old timer
Post Sun Nov 27, 2011 7:33 pm
be11 wrote:Cheers dude. The car is a touring
Standard E30 pump is fine.
be11
Post Sun Nov 27, 2011 7:36 pm
Just read that warning about pin 20 cheers Brian i'l check that, and thanks too eko
