waterpump/cambelt questions
jimbob29
does the cam belt run the waterpump pully?when you remove the tensioner to get at pump can the tensioner be used again?
You can re-use the tensioner but if you're replacing the belt its worth fitting a new one as they arent expensive - they can get noisy with age so its sensible to do as part of a cambelt change.
greg124
Tensioner for an M40 is only about a tenner from GSF
Schadenfreude - the German's haven't got a word for that.
