waterpump/cambelt questions
jimbob29
Post Wed Nov 23, 2011 12:06 pm
does the cam belt run the waterpump pully?when you remove the tensioner to get at pump can the tensioner be used again?
Post Wed Nov 23, 2011 12:58 pm
You can re-use the tensioner but if you're replacing the belt its worth fitting a new one as they arent expensive - they can get noisy with age so its sensible to do as part of a cambelt change.
greg124
Post Wed Nov 23, 2011 5:39 pm
Tensioner for an M40 is only about a tenner from GSF
Schadenfreude - the German's haven't got a word for that.
