Hi guys,
I have problem when I switch the parking lights and turn the ignition on the low beams starts illuminating than when I switch the low beams they lighting up fully. Checked the switch is ok, relay is ok. Have no idea what's happening. please help.
Headlights iluminating
TouringMatt
What year is the car?
Let me check im reading this right,
Ignition off - pull the switch to the first position, little parking lights come on
Ignition on - switch in the same position, main part of the headlight comes on
Ignition on - pull the switch to the second position, lights get brighter
johnl320
Mine does it too, its supposed to
blackgreg
TouringMatt wrote:What year is the car?
yes 100% that exactly what happens. Year - 1988
BenHar
It's called dim dip. Some sort of regulation at the time.
It's not a problem.
Ben
It's not a problem.
Ben
Sanchez
You can stop it by unplugging it if you dont like it. There is a black plug just inside the wing behind the nearside headlight.
It was introduced by BMW in anticipation of some legislation that never happened, but AFAIK is about to happen shortly.
blackgreg
Are you sure?? I had few e30 in my life and I have never seen it.
Absolutely sure. Discontinued around the end of '88 or early '89, I think.
blackgreg
he hey:) sort it than. That's good that I didn't dismantle the whole car.
Thanks Guys
Thanks Guys
BenHar
