Headlights iluminating
blackgreg
Post Sun Nov 06, 2011 10:38 pm
Hi guys,
I have problem when I switch the parking lights and turn the ignition on the low beams starts illuminating than when I switch the low beams they lighting up fully. Checked the switch is ok, relay is ok. Have no idea what's happening. please help.
TouringMatt
Post Sun Nov 06, 2011 11:48 pm
What year is the car?
Let me check im reading this right,
Ignition off - pull the switch to the first position, little parking lights come on
Ignition on - switch in the same position, main part of the headlight comes on
Ignition on - pull the switch to the second position, lights get brighter
johnl320
Post Mon Nov 07, 2011 12:07 am
Mine does it too, its supposed to
blackgreg
Post Mon Nov 07, 2011 8:19 pm
TouringMatt wrote:What year is the car?
yes 100% that exactly what happens. Year - 1988
BenHar
Post Mon Nov 07, 2011 8:45 pm
It's called dim dip. Some sort of regulation at the time.
It's not a problem.
Ben
Sanchez
Post Mon Nov 07, 2011 8:53 pm
You can stop it by unplugging it if you dont like it. There is a black plug just inside the wing behind the nearside headlight.
Post Mon Nov 07, 2011 10:23 pm
It was introduced by BMW in anticipation of some legislation that never happened, but AFAIK is about to happen shortly.
blackgreg
Post Mon Nov 07, 2011 10:30 pm
Are you sure?? I had few e30 in my life and I have never seen it.
Post Mon Nov 07, 2011 10:33 pm
Absolutely sure. Discontinued around the end of '88 or early '89, I think.
blackgreg
Post Mon Nov 07, 2011 10:55 pm
he hey:) sort it than. That's good that I didn't dismantle the whole car.
Thanks Guys
BenHar
Post Mon Nov 07, 2011 10:59 pm
