Rear inner tyre wear - touring
Grrrmachine
E30 Zone Wiki / Team Member
Post Sat Oct 29, 2011 10:08 pm
I've put my winter tyres on and noticed that one is pretty worn on the inside. I haven't lowered the car in any way, so I'm guessing something's wrong with my suspension.
Ruling out the ballache repairs of rear beam bushes, what else can I replace on the rear suspension to cure this issue?
I don't want to throw hundreds at it to refresh the whole back end though (well, I do want to, but I can't afford to)
Barx325i
Post Sat Oct 29, 2011 10:25 pm
too much sideways maybe? :D
leeparkes
Post Sat Oct 29, 2011 10:28 pm
Its common on E30's for the inner to wear first on the rears.
Post Sat Oct 29, 2011 11:51 pm
if its just one side something could be bent from a previous mishap. The arm or beam, do they look the same?!
Post Sat Oct 29, 2011 11:54 pm
Break out the string and the spirit level, and measure the suspension camber and toe.
Grrrmachine
Post Sun Oct 30, 2011 7:20 am
According to the last MOT sheet (when the geometry was done):
Camber: -0.53 and -1.11, when the tolerance is -2.30 to -1.30
Toe: -1.05 and -1.33, when the tolerance is -0.04 to 0.26
Not sure whether it's the toe or camber causing the issue, but I'm really hoping it's not a bent trailing arm...
